Ir para o conteúdo principal
Flagship smartphone from Huawei released April 2018. Model CLT-L29.
Huawei P20 password issues
Phone not excepting (correct) password on restart.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
There’s no way around the password prompt with encryption enabled. If you can’t get in, you’ll need to factory reset the device. You can factory reset in recovery mode:
  • Turn off your phone using the Power Button.
  • Once it is completely turned OFF, press and hold Volume Up and Power buttons simultaneously for a few seconds.
  • Release both the buttons once Huawei Logo is displayed on the screen.
  • Now you’ll be in recovery mode. You can select “Wipe data/factory reset” to completely erase your device.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
david otoole será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 29
Ao todo: 421
