Ir para o conteúdo principal
A1418 / EMC 3069 / 2017 / 3.0 GHz quad-core i5, 3.4 GHz quad-core i5 or 3.6 GHz quad-core i7 Processor. Released June 8, 2017.
176 Perguntas Visualizar todos
Firmware password removal by replacing hard drive?
So I bought this iMac with 1TB SATA 2.5 fusion drive on ebay but it has a firmware password on it. The previous owner got the machine from a pawn shop and couldn’t access it either.
I’m wondering if replacing the 1TB SATA 2.5 fusion drive with 2TB SATA 2.5 SSD with an OS Mojave already installed on the SSD will solve/remove the firmware password issue?
Thank you
Esta é uma boa pergunta?
Pontuação 0
1 comentário
Would appreciate any help, this is the only work station I have, thank you.
por
Adicionar um comentário
1 resposta
Solução escolhida
EFI firmware password is stored in the BIOS chip that's on the logic board so changing hard drives won't remove it.
Can't be removed without reprogramming or changing the bios chip.
Esta resposta foi útil?
Pontuação 3
1 comentário:
Thank you for the answer.
por
Adicionar a sua resposta
Wasin Rojanametin será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 3
Últimos 30 dias: 9
Duração total: 748
