How to change the batery
the PRIV battery is drainaging too fast. I want to change the battery
Update (02/11/2019)
the battery of my BB Priv is drainaging too fast after two years of usage . how to change the battery
Esta é uma boa pergunta?
(190) BlackBerry Priv Tear Down - Screen Repair, Battery Replacement - YouTube
Esta resposta foi útil?
Me too. My Priv battery was only good for a few hours. There are a few YouTube videos on how to change the battery, just Google “Blackberry Priv Battery replacement” and you can get a 3rd party battery on Amazon for around $50. An original is about $150 and up.
You need to power down and remove the SIM and memory cards before trying to open the case.
It can be a bit tricky opening the case, that was my only problem. It feels like you will break it by pulling too hard, but it won’t break. I had to review the videos a few times to feel confident pulling the case apart.
You need a special screwdriver for 2 screws holding the connector down.
You also have to be very careful and very slow to pull the old battery off the glue holding it down. You don’t need glue to reassemble.
Reassembly takes a very few minutes. Just make sure the power and audio buttons are well in place first and that the cover clicks into place all around. Replace the SIM and memory cards then power up and recharge and you’re done.
Últimas 24 horas: 1
Últimos 7 dias: 6
Últimos 30 dias: 31
Duração total: 2,265
