Ir para o conteúdo principal
2.0GHz, 2.3GHz, or 2.6GHz quad-core Intel Core i7 processor (Turbo Boost up to 3.8GHz) with 6MB shared L3 cache.
580 Perguntas Visualizar todos
The battery A1494 is compatible with the model A1398 of MacBook Pro?
In the website, I have only see the model A1494 for the MacBook Pro 15” Retina Late 2013. But for my macbook, it is the model A1398.
I want to know if this model is compatible before buy this battery.
Thanks you
Esta é uma boa pergunta?
Pontuação 5
1 comentário
These are all of the A1398 systems
por
Adicionar um comentário
4 respostas
Pergunta mais útil
Well you have selected the wrong machine:
This appears to be your machine:
Apple MacBook Pro "Core i7" 2.3 15" Retina 2012 Specs
Identifiers: Retina Mid-2012 - MC975LL/A - MacBookPro10,1 - A1398 -  2512
Here’s the battery for your machine:
COMPATIBILITY
  • MacBook Pro 15" Retina A1398 Mid 2012 to Early 2013
SPECIFICATIONS
Model #:
A1417
MacBook Pro 15" Retina (Mid 2012-Early 2013) Battery
Imagem de MacBook Pro 15" Retina (Mid 2012-Early 2013) Battery
Produto
$79.99
Esta resposta foi útil?
Pontuação 2
2 comentários:
Thanks you so much for the bad advise, The battery A1417 isn’t compatible. And know I have to resend the battery...
por
Sounds like you have a bit of confusion! What is your exact model
MacBook Pro's
The A1494 is the ID of the battery not the system (A1398). Once we know your exact system we can get you lined up with the correct battery.
por
@mayer is right and @jewel_g the iFixit kit is best if you want quality parts…….
Pontuação 2
2 comentários:
Welp... thanks for the note. I'll keep that in mind
por
your welcome (big fat cheesy smile)
por
Yes, this battery model is compatible with the Macbook Pro Model you mentioned.
Pontuação 1
Are you trying to buy a new battery? If so, you’re out of luck, as far as I can see. Try ordering one from Amazon, but before you hit order, check the reviews to see if it’s reputable.
Pontuação -1
8 comentários:
Why Jewel ? I want to buy a new battery and I think the iFixit kit is good
por
Well, I never noticed iFixit sold one. If you want to , go with that. Good luck!
por
Were are you looking that you came to that conclusion?
IFIXIT is one of the larger sellers of replacement batteries.
por
Amazon. (Laughs nervously)
por
Take the rose colored glasses off ;-}
IFIXIT does not sell directly on Amazon. Amazon is not where you find quality parts, mostly cheap knockoff junk!
por
Exibir mais 3 comentários
Adicionar a sua resposta
timothee.thouvenot será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 15
Duração total: 2,878
