Ir para o conteúdo principal
iPhone de quarta geração lançado em 2010. O reparo é simples, mas o vidro frontal e o LCD devem ser substituídos juntos, como uma unidade. GSM / 8, 16 ou 32 GB de capacidade / Modelo A1332 / Preto e Branco.
2375 Perguntas Visualizar todos
Pergunta encerrada
My iPhone4 doesn t work after lcd replace
Dear guys,
i had this problem: i replaced display and touch screen on my iphone 4 and saw all was good but after some hours i tryed to use charger and i had bad surprise: charger don t recharge battery and if i try to attack it to my computer it don t find it. So i tried to replace the dock connector and no luck, tryed to change cable , charger and battery and again no luck :(. So in your opinion what is the problem? what happened?
Best regards
Dan
Esta é uma boa pergunta?
Pontuação 0
1 comentário:
Does the home button work?
por
Adicionar um comentário
3 respostas
Most Likely you did something wrong when you replaced your display, did you mess with anything else BUT the screen when you replaced the display ? Try backtracking on what you did and reassemble your phone and try it again, you never know it you dont try.
Esta resposta foi útil?
Pontuação 0
1 comentário:
i tryed many time to reassemble it but no luck, i tryed also to use a recharger not apple and show the message "this charger it s no original" but not recharge too :(. Don t know what to do now.....
por
My experience says it can be the kabel of the charging port
it is fragile
Pontuação 0
4 comentários:
i tryed to change the charging port connector but no luck
por
That one [produto vinculado ausente ou desativado: IF182-009]
por
yes that one
por
i change display and all partsin my job and today the same problems. i changed display and touch screen on iphone 4 and after to have plugged and unplagged display into his socket in logic board the same problem. all the phone work right but it s impossible recharge it. Do exist a block that close the charge if some1 replace display many time or i m just unlucky?
por
did you make the connector the battery plugs into loose ?
http://www.iphonecentral.us/iphone-repai...
Pontuação 0
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 6
Últimos 30 dias: 6
Duração total: 5,042
