Ir para o conteúdo principal
Nikon's D3200 DSLR has 24.2 megapixels. This model is geared towards casual photography enthusiasts with advanced specifications and performance.
64 Perguntas Visualizar todos
How to replace the sd card cover on nikon d3200 camera
The exterior door/cover for the SD card slot broke. I can obtain a replacement door, but do not know how to replace it. Any resources?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Not sure how close the screws will be to that panel, might want to look at the replacement part for where it has screw holes!
I took that part off while doing other work, on my D500, and although it showed 2 screws, there were 4 more hiding under 2 pieces of rubber! May need to peel the rubber up around the door to find them.
Nikon D500 Memory Card Cover Disassembly
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Jim Keller será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 3
Duração total: 482
