Ir para o conteúdo principal
Touch screen not working
Can I connect the six pin ribbon to the six dots on the board if the connector for the ribbon is destroyed
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Hi Mike, it sounds like there is an issue with the ribbon cable? If that is the case, you should just order the part from eBay or a wholesaler and if you are comfortable enough I would say go for the soldering. Just remember it is a different thing soldering on computers vs micro boards like phones.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Mike será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 2
Ao todo: 107
