Starting problem, restarting again
My laptop is not starting. After pressing power button it starts and then restart again and again.
Esta é uma boa pergunta?
Hey Atul,
I Think If you are a Microsoft Windows User, Then This has Become a Common Problem With Many Diffrent Machines..And It Will Not Matter How Mutch You Spent On the Laptop Or Even Its Specifications..
Ok, So Here I Might Be able to Assist You, (See Below)
Microsoft Has a Reputation For sending Corrupted Updates To All Windows Users..and Your Problem Has Strong Resemblance In This Catagory.
I Will Advise You At This Point To Use..
# The Original System Repair Disk That Came With The machine..
# If you get Into “Safe Mode“ You Should be able to use your Backup & Recovery from an External Scource, Meaning (External Storage-USB/DVD/External Hard Drive/MMC) ext. & Because you are inside Windows again, you can find what you need in System Settings (Controle Panel)..
Let Me Know How You Get On With This.. Try These First And Contact Me Here On this Site, So People Can See The Possible Solution Unfolding…
I Will Be More Of Assistance With More Knowledge Of Your Problem..
Marty..
Esta resposta foi útil?
Últimas 24 horas: 6
Últimos 7 dias: 8
Últimos 30 dias: 11
Ao todo: 315
