Ir para o conteúdo principal
The Lenovo IdeaPad 110-15ISK was developed in the United States by Lenovo in 2015. The Lenovo IdeaPad 110-15ISK can be identified by its model number: 80UD.
7 Perguntas Visualizar todos
Why is ny battery not charging
Why is my battery not charging?
Esta pergunta é pertinente?
Pontuação 2
Adicionar um comentário
2 respostas
Pergunta Mais Útil
You need to check the charging module, the charging port and the battery itself.
Esta resposta foi útil?
Pontuação 2
2 comentários:
the same applies to V110-15ISK Laptop (Lenovo) - Type 80TL?
por
First thing I would do is try another charger, otherwise it'll be battery if you see the battery health wear level being over 40% which you can check with HWMonitor.
por
maybe your cable is broken and the you habe to buy a new cable or repair it
Pontuação 0
Adicionar a sua resposta
Scentsymom14 será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 5
Duração total: 331
