Ir para o conteúdo principal
No Rear Camera or Flash/Torch After Battery Replacement?
I just purchased a replacement battery and followed all the instructions exactly but now my rear camera doesn’t work, it’s iust black. Also, my flashlight doesn’t work anymore. Thoughts?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Did you disconnect the old battery before removing the screen before installation of the new battery?
Esta resposta foi útil?
Pontuação 0
3 comentários:
Yes I did. I followed all official instructions.
por
It sounds like you have a hardware issue, but I just to be safe have you tried restoring the phone to factory yet? Dont restore from a backup as if it is a software issue, itll copy over.
por
Yes, I have tried to restore it but that didn’t work. I opened it back up again to check the camera ribbon and make sure it was connected properly and everything else looked good. Rear camera is just black and the flash doesn’t function still.
por
Adicionar a sua resposta
Tyler Burgess será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 1
Duração total: 72
