Where's Developer Mode Switch?
The Developer mode switch is supposed
to be in the battery compartment or
behind a removable panel.
It's a very important feature and you
don't mention it all. where is it
located at?
Esta é uma boa pergunta?
located at?
The dev switch is accessable without opening the device. It is on the right hand side of the device behind the SIM slot cover.
Edit: You can see it right below the SIM slot on the Step 14 teardown picture.
Esta resposta foi útil?
I Have a chrome book and have looked behind the panel where it is supposed to be and there is not a switch there, the hole is but there is not a switch to use?
Any ideas?
robert clench, did you confirm this by checking the image of the teardown?
From what I've read, the developer switch is only on the CR-48 (Prototype/Developer Chromebook) It isn't found on retail models.
Not according to what's stated in here. http://goo.gl/b2Fl2
Shell access is only available in Dev mode, if it's not included, a lot of people are going to be angry.
The Dev Switch Is On The Right Side Of The Unit, Where The Sim Card Slot Is Located, It's A Switch That Can Be Toggled With A Pin (Paper Clip) Or The Tip Of A Pen.
So you are confirming what "no way" answered in June of 2011 correctly. Good Job ;-)
Wow apparently so , I guess that's what happens when you don't bother to read all posts. My apologies.
Yup, happens all the time ;-)
how do u use the switch
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 25
Ao todo: 11,576
1 comentário
mine was a device that had no switch near the sim , instead it was inside the small hole in the case to the right of the power button
por Brandon Gallagher Compartilhar
