No heat but power on my toaster oven?
My Black and Decker convection oven has power( red light on) but no heat (heating bulbs don’t work)
Esta é uma boa pergunta?
Hi Lynn,
Has this just randomnly occured or was it during use? It could be that the bulb(s) may have blown as this is a typical thing to happen to toaster ovens through all of the heat cycles they experience they can wear out rather quickly. I would suggest an over heat protection feature although you stated the red light is on meaning this is not the case. Do you have the model number and I can take a closer look at a possible solution for you.
Esta resposta foi útil?
I have the same problem with my Elite toaster oven, model #ERO-2008S
Últimas 24 horas: 0
Últimos 7 dias: 13
Últimos 30 dias: 45
Duração total: 1,758
