Ir para o conteúdo principal
Repair information for the Fitbit Ionic. A smart watch with GPS tracker and music player on bluetooth. This device has been recalled for safety reasons.
20 Perguntas Visualizar todos
Replace screen Ionic - Ionic
I have an Ionic with a damaged screen and the replacement worked until last week firmware update… it is dead since then…
How could I replace the screen from the dead one to the broken screen but working ?
Esta é uma boa pergunta?
Pontuação 2
1 comentário
I found this tutorial on youtube: https://www.youtube.com/watch?v=vZdALycI.... Would be great to see it on IFixit along with parts....
por
Adicionar um comentário
1 resposta
Solução escolhida
Remove the strap from the wrist
heat the watch slowly to approx. 80 degrees Celsius
gently(!) place a opening tool between the glass and the frame of the watch and lift the glass carefully and slowly
disconnect the connectors
replace the glass
put everything together
WARNING: Be very carefull, since the rubber seal between the glass and frame is easily damaged and you need it to seal the watch. I haven't found any spare part for this yet and I did not managed to preserve it.
Esta resposta foi útil?
Pontuação 1
1 comentário:
Hi! I also have a broken glass on the Ionic. Where can i find the repair guide and parts?
por
Adicionar a sua resposta
Jesus Fernandez será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 3,017
