Ir para o conteúdo principal
Released September 21, 2018. Models: A1921, A2101, A2102, and A2104 / Available as GSM or CDMA / eSIM or nano-SIM / 64, 256, or 512 GB / Silver, Gold, or Space Gray (Pronounced "iPhone 10 S Max.")
Why is no connectivity sometimes while using mobile data?
All on a sudden there is no connectivity to the internet through mobile data. This is happening sometimes with my device. Page loading loading…. The connection reinstates immediately when the phone is restarted. Wifi connections work completely fine. What should i do with this case?
Esta é uma boa pergunta?
Pontuação 2
Adicionar um comentário
1 resposta
Solução escolhida
Have you already installed the iOS 12.1.3 update? if so then what your describing happens to a lot of apple users. this link http://osxdaily.com/2019/01/26/ios-12-1-... should help you fix the problem. Other than that have you tried rebooting it in airplane mode or resetting the network settings?
Esta resposta foi útil?
Pontuação 0
1 comentário:
Hope this was useful for you
por
Adicionar a sua resposta
Tanvir Rayhan será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 2
Ao todo: 378
