Ir para o conteúdo principal
The Samsung Galaxy Tab 2 10.1 is a 10.1-inch Android-based tablet computer and belongs to the second generation of the Samsung Galaxy Tab series.
133 Perguntas Visualizar todos
Upgrading to latest Android version manually
Hi there, I have an old Samsung Galaxy Tab 2 10.1 with Android version 4.0.4. Nothing is compatible with it anymore. How can I upgrade it to the latest Android version please? I have checked and it says no updates available
Esta é uma boa pergunta?
Pontuação 40
7 comentários
Thank you so much
por
Yes, you can upgrade to Android 6 Lineage 13.0, I have Samsung tab 2 10.1 with that
por
Thank you so much Stephen. Much appreciated. How did you upgrade please?
por
I have samsung tab 2 and playstore dont want to work
por
I too have a Samsung Galaxy S - model number SM-T800 - running Android 6.0.1
When I check the updates it says it is up to date.
I would like to download an Application - Imaging Edge Mobile from Sony, so that I can check photos and videos taken on my Sony camera HX60V - It says the software is not compatible and I require Android version 7 at least to install the software.
How can I update the Android Version on my tablet?
por
Exibir mais 2 comentários
Adicionar um comentário
3 respostas
Solução escolhida
here you go
you need to install a custom rom
Android is modified by the manufacturer to work on their device, because every device has different hardware.
https://www.youtube.com/watch?v=7V5tZi5V...
Esta resposta foi útil?
Pontuação 8
4 comentários:
I have two Tab 2's - both at now too slow to use. Wanted to see if there was a way to update. the link above is marked Private.
por
This was rubbish. The video whizzed through so fast and without explanation so that it was impossible to follow.
por
the video has gone private
por
As others have said, the video is private.
por
If you go to [http:// https://forum.xda-developers.com/t/how-t...|XDA’s website] by clicking the link it should bring you directly to the how to’s of the tab 2. there is all kinds of valuable info on this site and if utilized will hopefully give you a better understanding of your gadgets. Good luck!
Pontuação 3
1 comentário:
Thank you William. That link was incredibly helpful!
por
Try googling (samsung android tab 2 update ) and it will tell you how and where to go
Pontuação 1
Adicionar a sua resposta
Jackie Barton será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 30
Últimos 7 dias: 193
Últimos 30 dias: 1,102
Duração total: 70,912
