Ir para o conteúdo principal
A 10.1" touchscreen tablet released in 2014 by RCA Corporation.
How do I get my settings and start to work?
I have an RCA laptop (the keyboard is detachable) I factory reset it without back anything up and now I I can't open my settingsister or my start and Internet Explorer isn't on here, what do I do?
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
Solução escolhida
You will be ok! :}
Power down by holding the power button down until it goes dark.
Power back up and get ready to press the F8 key repeatedly when you see your RCA logo splash scene.
You should see some options here for safe mode or recovering your last known ‘good configuration’ if need be.
You will need to restart and see which gets you closer to your last desktop.
You will have to reinstall all your apps because of the factory reset.
If Edge and IE are still missing you will find them in ‘add addition windows components’.
You may need to Remove and add back and you should be good :) I hope…
Good luck!
Esta resposta foi útil?
Pontuação 0
1 comentário:
I had to remove my keyboard because it stopped working how can I do all of that without the keyboard?
por
Adicionar a sua resposta
Te'Shanna Jones será eternamente grato(a).
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 6
Últimos 30 dias: 12
Ao todo: 382
