Ir para o conteúdo principal
Why is touch screen not working
I replaced the battery per instructions and now touch screen does not work. I hard restarted it, no good. I disconnected and reconnected cables multiple times - no good. I cleaned connectors with alcohol - no good. I tried to connect to iTunes but computer doesn’t recognize it. I am lost.
Esta é uma boa pergunta?
Pontuação 0
1 comentário
It is an iPhone 6S Plus
por
Adicionar um comentário
1 resposta
Pergunta mais útil
Hello,
Look at the strip link for the screen for the tears on the off chance that you left in appended while you pulled the battery, have Witnessed this various occasions when individuals cut corner pulling the battery.
It would be exceedingly far-fetched that board harm happened I would think changing a battery, except if you were simply too indiscreet.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Don Wells será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 1
Duração total: 66
