Ir para o conteúdo principal
Burnham steam boiler PIN4SNI-ME2, PSI valve replacement
I have the part, but is not sure how to uninstall old and install new. Do I simply unscrew it from the body of the furnace and install the replacement PSI valve. Anything I should be aware of (except, of course that the furnace needs to be off and cold when I do this)?
Many thanks, SE
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
Here’s the service manual for your boiler Burnham Independence Boiler
Pressure valves are a very tricky thing. If not installed properly you can cause big issues!
I strongly recommend you get a trained heating technician in to install it for now. If you really want to learn go to a good vocational school to study heating.
Just the other day a home near here blew up! The homeowner tried fixing his boiler and now he’s homeless!
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
sam engelstad será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 9
Últimos 30 dias: 17
Duração total: 195
