Ir para o conteúdo principal
The Kenmore Elite HE3 is a washing machine by Kenmore.
669 Perguntas Visualizar todos
Loud knocking noise during fast spin cycle.
My washer has a loud knocking noise during spin cycle. There are chewed up pieces of plastic mixed in with the clothes. Is this a bearing?
Esta é uma boa pergunta?
Pontuação -1
3 comentários
Paul, What did you determine with your washer? Mine is doing the exact same thing, with the loud noise and the bits of plastic. I'm not sure if trying to fix it will be a money pit or if I am better off biting the bullet and purchasing a new one.
Thanks
por
I just decide to replace it. I called a couple of repair persons and they all thoght it would be expensive to repair. I forget exactly what they told me but I wasn't going to pay sombody $55.00 to find out. Consumer's report magasine recommend to replace the washer because it was too old to repair. Luckily I was in a situation to do just that. Sorry, I can't tell you what was wrong.
Paul
por
I dont know either ,I just took apart my back cover and ran it on rinse spin cycle for 11 min and the noise is still there although no clothes in washer. everything seems tight and no other noise except on fast spin.
por
Adicionar um comentário
4 respostas
Solução escolhida
Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary. Does the plastic match any inside the machine?
Esta resposta foi útil?
Pontuação 3
We had the same problem, we were told by a repair person that the "spider" on the stainless steel tub corrodes and breaks. We took it apart just to see if he was correct and he was. The SS tub goes for about 300 +. Not worth fixing. We purchased a new one.
I can understand the problem with the smell that everyone complains about. When we disassembled the tubs there was a lot of crud caught in between the spider. Disgusting!
Pontuação 0
I had the same problem and determined the plastic parts were the edge of the front tub enclosure being chewed up by the spinning-moving stainless tub. Thought it was a failure of the front enclosure so ordered a new one and replaced it myself. Turns out I treated the symptom and not the problem - a $250 lesson! It seems the problem is further back and requires complete dis-assembly and more parts so I am giving up on this one and buying a replacement.
Herb
Pontuação 0
I just finished running the washer with the back cover off. What I found was the aluminum wheel that the belt goes around has worn in the center and there is slop in the rotation which I believe is the cause of the problem. I can't wait to get rid of this tragic excuse for a washing machine. Maybe Kenmore will offer me a bata model with which they want me to test for them in real home like conditions. Whataya say Kenmore??
Good Luck, Greg W.
Pontuação 0
Adicionar a sua resposta
Paul será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 9,774
