Ir para o conteúdo principal
Bluetooth and Wi-Fi Not Working After SSD Install
Hi everyone,
recently I installed an SSD unit in my iMac 21,5’ Mid 2010. Unfortunately, even though the SSD is correctly detected by the machine, I’m not able anymore to connect to Wi-Fi or pair Bluetooth devices.
On the Bluetooth icon I get: no Bluetooth available.
For both Wi-Fi and Ethernet, instead, I’m able to connect to networks (which means that the Airport card should be working at least) but I have no connectivity at all.
I already tried SMC and PRAM reset but nothing changed.
Regards
Francesco
Update (01/17/2019)
I’ve finally installed Mac OS on the new SSD drive. Everything is working fine except for Bluetooth.
I also managed to re-open the computer to check if the Bluetooth module was disconnected, but it appeared to be fine. Everything was in place and the plastic tape around the module was not even touched.
I really do not get why I’m not able to use Bluetooth anymore.
Image of the internals:
Update (01/17/2019)
Hi. I checked the connections on the logic board as suggested before. Here's some images:
https://i.postimg.cc/HLqCQ3QK/IMG-201901...
https://i.postimg.cc/FsT5Phy0/IMG-201901...
https://i.postimg.cc/d0Tbtdz9/IMG-201901...
Everything is connected and seems to be fine.
Update (01/19/2019)
Here I am. Another day is gone and unfortunately my solution is not here.
I really do not know what else to do. Today I’m opening the machine again (for the fifth time) trying to see if everything it’s in place.
Sometime the Bluetooth works (only in recovery mode), but after the OS installation is complete it is not detected anymore by the machine.
Update (01/19/2019)
This is what happens
Video 1
https://www.youtube.com/watch?v=5k43vyw7...
Video 2
https://www.youtube.com/watch?v=M74c0u5V...
When I’m in recovery mode/selection of the boot hard drive, everything works… but then, just after installing the OS, Bluetooth dies.
Please watch the video. It’s clear that it is not an hardware problem, to me.
Esta é uma boa pergunta?
Pontuação 1
7 comentários
Clean the blob off the cables in Pic #1 This is likely a patch someone did and thats the failure.
por
Hi Dan.
Unfortunately my issue isn't solved yet.
After removing and cleaning the RAM modules as previously suggested I was able to see Bluetooth again.
Then I decided to install again OS X on top of my new SSD and everything went fine until the first boot when Bluetooth disappeared again.
I don't understand what you're suggesting me to do right now. What should I clean?
por
In your first picture here on the far right wires is a blob of glue covering them clean it off as the wires are broken under neath
por
Yes, take the tape off so you can inspect the connections.
por
Exibir mais 2 comentários
Adicionar um comentário
2 respostas
Pergunta mais útil
@bacchinif - Some of us need a few zzz’s at night.
You’ll need to check your connections on the logic board side as marked in Red here
Either you’ve put the wrong cable onto the connection or the connector is damaged (cable or board) so its not making connection.
Esta resposta foi útil?
Pontuação 1
7 comentários:
Hi. Thanks for your prompt response. I'm Italian, which means I'm living in a different time zone. I didn't intend to bother the community, but you may understand that I'm pretty worried for what happened.
Thanks also for the image posted, but it looked like my internal scheme may be a little different. I don't have the Airport Card (the one with the yellow box highlighted) in that position. Could it be?
I followed the Bluetooth replacement guide on iFixit and I thought that the Bluetooth Module was placed in the top left corner of the iMac. Am I right?
At the moment I'm running Apple Hardware Test.
I got an error:
4MEM/9/40000000: 0xb9860918
por
This system has two boards: Bluetooth board and a WiFi board.
As you can see here Finding Hardware Faults: Exploring AHT & Apple Diagnostics the 4MEM error is a memory module failure. Thats a different problem! Did you properly reseat the modules?
por
I didn't touch them. The RAM modules are not giving me any sort of problem at all. I installed more than 5 years 4x4GB of Crucial RAM.
What do you mean by "reseat"? They remained untouched during the SSD Installation procedure.
por
Carefully remove the RAM DIMM's, clean the contacts using a new (soft) pencil eraser going in the same direction as the gold pads one or two rubs then wipe the contacts using 85% or better isopropyl alcohol.
por
Solved my issue! The problem was due to an excess of dust in the ram modules!!!
por
Here I am… Typing from the iMac with the Bluetooth Keyboard turned on. I’m in recovery mode right know, and I’m running that light version of Safari.
The fact that again Bluetooth is working only when I’m in recovery mode/installation process means that it is NOT a hardware problem, but some more specifically connected with lack of drivers or compatibilities when I’m running the OS via SSD Drive.
Could it be? I really do not know what else to think.
The Bluetooth Module isn’t damaged, all the cables are fine and everything works but ONLY when I’m in recovery mode.
Aggiorna (22/01/2019)
Solved my issue! The computer was extremely dirty inside and I cleaned it using an hairdryer on cold.
Pontuação 1
1 comentário:
Well the video might be help you out in fixing the issue : https://www.youtube.com/watch?v=pwaz8Mf4...
por
Adicionar a sua resposta
Francesco será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 4
Ao todo: 1,072
