Ir para o conteúdo principal
A quarta geração do Volkswagen Jetta, também chamado de MK4 ou Bora, é o sedã familiar da Volkswagen.
While I drive my rpm jumps and my car goes into a neutral like state?
While I drive my rpm jumps and my car goes into a neutral like state for a minute or so.Any clue to what may cause this? Car:2005 New Jetta
Esta é uma boa pergunta?
Pontuação 2
Adicionar um comentário
1 resposta
Solução escolhida
I have the same car/same year with 209k miles. My unit initially manifest your question described symptoms gradually starting only when you’d “jump on it” make a request for acceleration and it would over-rev the tach with no related presence of actual acceleration.
Lived with that for 1 year until going down the road at 70 mph, the tach would flicker up & down +/- 200-500 rpm inepite me actuating no change in the foot position of the accelerator pedal.
That trans failure was described as “neutraling” by the reputable shop I at length consulted with.
They said with clocklike reliability, they see VW auto trans going for 150k-225k mile intervals between major systemic failure. I ordered and bolted on a reman.
Esta resposta foi útil?
Pontuação 1
1 comentário:
So Wat was the main problem that was causing that
por
Adicionar a sua resposta
Willson será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 8
Ao todo: 485
