Ir para o conteúdo principal
The Toshiba Satellite CL15t-B1204X notebook is an entry level Toshiba laptop made in 2015. It uses a small form factor with an 11.6" screen and a sleek silver chassis.
Power button not turning on
Hi, my laptop is fully charged yet the power button doesn’t feel like its working. The light next to it doesnt turn on and neither does the laptop’s screen. I know its charged because the battery light is white which means its fully charged. I don’t know what to do.
Esta é uma boa pergunta?
Pontuação 2
2 comentários:
Has is taken a fall recently, or was something dropped on it? Basically, I'm asking if there is anything that might've physically happened to it.
por
Old buddy of mine showed up at my door the other day with the same laptop and the same problem. It does look a bit beat up but nothing deadly. I took the bottom cover off to give it a quick look and it looks like the power button might need reseated or replaced. Once I have the time to take a better look. I will let you know what I find out.
por
Adicionar um comentário
1 resposta
If your Toshiba computer won't turn on or becomes non-responsive. Try performing a soft power cycle. If the computer is still non-responsive or won’t turn on try performing a hard power cycle to restore proper operation. The explanation below will help you in performing these tasks.
Soft Power Cycle:
  1. Press and hold down the power button for 20 seconds or until the computer shuts down.
  2. Press the power button to turn the computer back on
  3. If this did not resolve your issue continue with the Hard Power Cycle procedure
Hard Power Cycle (For computers that have removable batteries):
  1. Unplug the computer from the AC adapter.
  2. Remove the battery from the computer.
  3. Press and hold the power button for 20 seconds.
  4. Re-Install the battery.
  5. Re-Connect the AC adapter.
  6. Press the power button to turn the computer back on
Update (03/07/2019)
video
https://www.youtube.com/watch?v=GFehLaJP...
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Bea Philippe será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 20
Ao todo: 7,165
