Ir para o conteúdo principal
A 64.52" LED 2160p 4K UHD Television released in 2015.
12 Perguntas Visualizar todos
must power cycle to get pix
VIZIO P702ui-B3 If off for more than a few hours the led (lower left corner) lights, Audio works, but no picture. If power cycled 2 or 3 time it turns on normally.
This happens with the remote or the manual switch on the set.
I’m thinking about replacing the power supply. Could that fix it or perhaps the Tcon board?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
I had a similar problem with my P55-C1 (audio, no picture). I used a flashlight and discovered that the picture was actually working but the backlights weren’t coming on. I replaced the LED driver boards (four of them) and now I have a working picture again.
Esta resposta foi útil?
Pontuação 1
1 comentário:
where do you find a driver board? Would you post a tutorial on replacing it please?
por
Adicionar a sua resposta
Greg “Bad Kitty” Arikian será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 372
