Transmission leakage on 2007 Camry after shaft replacement
My local mechanic replace shaft on my 2007 Toyota Camry. After the shaft replacement the transmission started leaking out ATF fluid and could not engage gear to drive but only reverse. He called the transmission guy who came and inspect and told me I need a new transmission that my car has 13 pin Auto transmission type (what ever that is) and is not the type that can be worked on.
I was completely shocked. The car never had any transmission problem. The problem I had was hearing shaft noises when making turn and I decide to replace it. I was thinking the leakage was something that might have to do with shaft seal that can be replace but telling me i need a new transmission is unthinkable.
Please is it true that my Auto transmission is totally damage from shaft replacement ?
Esta é uma boa pergunta?
