Ir para o conteúdo principal
Guias de reparo para o MacBook Air, a linha atual de laptops da Apple.
A1466 - How to identify the Logic Board
In looking to repair an Air, I have determined that somehow someway a liquid got inside the case. It does not charge at all. No green light.
Bought a new battery and installed it, but that did not solve the issue.
So … is this an I/O board issue? Was the logic board fried? How can I identify the specific model of the logic board or the laptop itself? One of the capacitors is marked as “4R7 433 5AM” below what I believe is the wireless card.
Thanks in advance for the reply.
Esta é uma boa pergunta?
Pontuação 1
1 comentário
Thanks. I did not look closely enough. That site is a great tool!
Now … time to determine how much this will cost me to repair :-)
por
Adicionar um comentário
1 resposta
Solução escolhida
The easiest method would be to look up the serial number on the back case of the laptop. Powerbook medic has a search tool for it.
http://www.powerbookmedic.com/identify-m...
Esta resposta foi útil?
Pontuação 1
14 comentários:
What if the bottom case was not from the same unit but from another unit of the same model?
por
@livfe check the 820-xxxxx number on the board :-)? Last time Charlie B was seen on here was 6yrs ago
por
@oldturkey03 Board number is irreverent to discover the macs serial number ;)
por
@livfe you sure? After all, you can identify which computer it is by what logic board it uses :-) but I was really focused on the original question "How to identify the Logic Board"
Hope all is well with you and that things are going good for you. Haven't seen you around much lately ;-)
por
@oldturkey03 All well, been around a lot on here recently, made a new guide etc.... My Q here was how to see if the serial of the board matched the one on the bottom case for example.... I know the board number :)
por
Exibir mais 9 comentários
Adicionar a sua resposta
UNvrFightAl1 será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 11
Últimos 30 dias: 41
Ao todo: 4,953
