Ir para o conteúdo principal
The sixth-generation Volkswagen Jetta, known as the NCS (New Compact Sedan) during its development, was announced in the North American market in June 16, 2010.
Where is the intake runner postion sensor located
need to replace intake runner position sensor
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
If it’s an error code p2015, It’s on the right side of the intake. There can be many reasons for it failing. It can be bad, jammed, gunked up with carbon inside the intake, broken actuator arm, etc. Make sure it’s moving correctly before replacing the sensor. Manually actuate it by hand.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Donnie McClellan será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 4
Ao todo: 157
