Ir para o conteúdo principal
Released June 2009 / 2.53 GHz Core 2 Duo Processor
170 Perguntas Visualizar todos
Mid 2009 internals into 2011 model?
I’ve got a mid 2009 2.53 GHz Macbook Pro from college that had snapped at the lid bracket. I went through alot trying to fix it myself and managed to ruin the bluetooth, wifi, and webcamera connection ports.
A new display assembly would be great but at $325 for C-Stock its not really in the budget. I managed to find a few A1286 models on eBay for $120, no HDD, no RAM basically just for parts.
My hope was to take the internals from my mid 2009 model and give life to a 2011 model while also upgrading the RAM to 16GB (or 8 should it not work).
Has anyone had any experience doing something like this? Is it as simple as pulling the HDD and other components and plugging them in?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Solução escolhida
Well you can salvage your HDD putting it into your 2011 system.
The RAM on the other hand can’t be reused as it’s the wrong specs
  • Mid 2009 - 204-pin PC3-8500 (1066 MHz) DDR3 SO-DIM
  • Early 2011 - 204-pin PC-10600 (1333 MHz) DDR3 SO-DIMM
I hope the system you buy is functional.
Esta resposta foi útil?
Pontuação 2
Pergunta mais útil
Sorry, but you’ll have to forget about A1286 i5/i7 display assemblies for your 2009 model, they have entirely different connectors and will not fit. However, if you have a little patience, I’m sure you’ll be able to find a used display at a decent price..consider that right now, for the price you mentioned, you can almost buy a full Macbook Pro of the same series you have.
Pontuação 3
Adicionar a sua resposta
MotoRickyRicardo será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 6
Duração total: 67
