Ir para o conteúdo principal
Wi-Fi only version of Apple's 2nd generation iPad Air. Model A1566.
Lighting jack is not working
My iPad Air 2 is not charging. I’ve tried restarting the device, cleaning out the lighting port, changing cords, chargers, and wall outlets to no avail. I was looking for other ideas as tot he cause, or for a replacement part to replace the defective part.
Esta é uma boa pergunta?
Pontuação 1
1 comentário:
Thank you all for the info. Much appreciated!
por
Adicionar um comentário
2 respostas
Unfortunately, your port may be defective. It is soldered to the Logic Board and would require micro-soldering to be replaced. If you want to repair it, it may be cheaper to take it to Apple, as micro-soldering can be very expensive.
Esta resposta foi útil?
Pontuação 0
You can buy a replacement charging dock voor the ipad air 2 it isnt that hard to repair no soldering needed , buy one with flex cable.
Pontuação 0
2 comentários:
The charging port flex assembly is connected via soldering to the logic board. So it will require soldering to replace that charging port.
Good video on how it's done here: https://www.youtube.com/watch?v=IdyIQYrO...
por
Alec and Ben , sorry you are right. For the normal ipad 2 it is easier and with a flex cable.
por
Adicionar a sua resposta
Ryan Lantz será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 53
Ao todo: 470
