Ir para o conteúdo principal
Released in 2015, RX100 IV, 4K Cyber-shot digital camera
Display will not invert in selfie mode
I have a Sony RX100M5. When I flip the display up in selfie mode, the image will not change to selfie mode. It stays inverted. When If I place a small magnet at a particular place on the housing, the image inverts as long as the magnet is there. Then it always stays inverted even when display is is brought to normal position.
Esta é uma boa pergunta?
Pontuação 0
1 comentário
Thanks for your answer. I will try that.
por
Adicionar um comentário
1 resposta
Solução escolhida
I think what you can do is just revert the magnet under the screen. This happened to me when I dropped my RX100m3 but then I opened it again and flipped the magnet and it worked well.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Surinder Bhamra será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 6
Últimos 30 dias: 19
Ao todo: 1,093
