Ir para o conteúdo principal
iPhone 6 turns off by itself
Hello everyone,
I’ve an iPhone 6 that turns off and turns on alone.
I do not know why. I was already, restore the phone, change the battery and the screen because when the screen is off, a horizontal line (red, green, blue or white) appears, but the problem continue.
I think the problem comes from the motherboard but, I prefer to be safe.
Thanks if, you have any ideas.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
It could be that the power button is stuck
Update (01/06/2019)
There is a little antenna style connector on the bottom of the board below the battery connector make sure that connector is on all the way I had a similar issue once
Esta resposta foi útil?
Pontuação 0
1 comentário:
No, I don't think because, when, I put it in DFU mode, it stays in this mode.
But, when the restoration begins, the problem come back.
por
Adicionar a sua resposta
Anthony Fassler será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 1
Duração total: 53
