Ir para o conteúdo principal
The Nintendo DS is Nintendo's seventh generation handheld game console and is the first of its kind across all systems with dual-screen technology and use, apart from clamshell Game & Watch systems.
20 Perguntas Visualizar todos
DS No Longer Working After Disassembly
I decided to open up my original DS so I could clean some dust. After cleaning the dust from inside my DS, I tried to power it on but the green light momentarily powered on for a split second along with the bottom display. I then took it apart again to make sure I plugged in every ribbon cable but when I put it all together and plugged it in, there was absolutely nothing except the speaker pop when you press the power button. I plugged my DS into the wall and tried powering it on but still experienced the same issue but with the orange charging light on. Can anyone help?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Hi
i had the same symptoms with a incorrectly inserted wifi module. Have a try to unplug it and replug it
Esta resposta foi útil?
Pontuação 0
1 comentário:
You can’t remove the WiFi module on the original DS so I just unplugged and plugged the antenna to the WiFi module and it didn’t help.
por
Adicionar a sua resposta
TheLoneGamer será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 1
Ao todo: 155
