Ir para o conteúdo principal
The Hover-1 Liberty is a self balancing e-scooter or hoverboard. It has a max speed of 7.4 mph, a max weight capacity of 160lbs, and it can travel 3 miles on a full charge. It also comes with LED wheels and Bluetooth capabilities. Model: HY-LBTY.
Wheel does not seem to be straight
The one wheel on my daughters hover board is not straight and moves quite a bit compared to the other.
When I opened it up there were little black bits ??? Compared to the other side it looks like a plastic clip is missing?
Is there a way to staibilize the wheel? Hover 1 won’t help us due to the receipt is not with us as it was a gift …
Esta é uma boa pergunta?
Pontuação 2
Adicionar um comentário
1 resposta
Pergunta mais útil
I’d first check the bearing. Use a magnet to tell if the bits are metal or plastic.
Esta resposta foi útil?
Pontuação 1
1 comentário:
all bits are plastic and wheel goes down at last i used only 2 times
por
Adicionar a sua resposta
Les hill será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 6
Ao todo: 299
