Ir para o conteúdo principal
Model A1040 / 10, 15, 20, 30, or 40 GB hard drive / four touch-sensitive LED backlit buttons above touch wheel
97 Perguntas Visualizar todos
iPod not syncing to iTunes. New battery. Swapped HDD with compact SD.
I have a 3rd gen classic iPod. Replaced the battery and swapped out the original hard drive with a compact flash memory card. When I plug it in to my computer iTunes does not recognize it. The screen shows the Apple then the drive with the “!" Does this mean the cable and/or the logic board are bad?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
iPods will not sync via FireWire after the hard drive is replaced with flash storage. You need to use a Y-cable to sync it. One end should be plugged into a FireWire charger, and the other end into the computer.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Seth Aronson será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 5
Duração total: 70
