Ir para o conteúdo principal
Repair guides and disassembly information for laptops manufactured by ASUS.
2525 Perguntas Visualizar todos
Q505UA: How do I remove the bottom panel.
Purchased and Asus Q505UA 2-in-1 laptop for Xmas and I'd like to swap the 1tb 5400 rpm platter drive for a 1tb Samsung Evo 860. I've removed all 10 screws from the perimeter of the bottom panel, but it doesn't seem to want to separate with even moderate pressure. I've checked under the front and back fee at didn't find any more screws (Q504 had these).
Has anyone here taken this panel off of a Q505UA? If so, do I just need to be more forceful in trying the panel away or is there some other trick or fastener of which I should be aware?
Esta é uma boa pergunta?
Pontuação 2
Adicionar um comentário
1 resposta
Pergunta mais útil
Bottom case should go relatively easy off on this model.
But. There should be 11 screws on the bottom case - make sure you have removed the screw tape in the center that’s hiding the last screw
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
rob será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 2
Duração total: 312
