Ir para o conteúdo principal
Modelo A1311 / Final de 2009 / Processador Core 2 Duo de 3,06 ou 3,33 GHz
My iMac is dead, won't turn on...
I was using my iMac, browsing and making some music. I turned it off (the back of the computer was very hot) the next day I tried to turn it on but it just won't turn on. No display and no sound, did every thing I could do except reseting the PRAM because my iMac come with a wireless keybord so I can't give any input to the iMac (Lost contact with the mac). I recon that the power supply is the problem.
Anyway, what IS the problem? And what should I do?
Esta é uma boa pergunta?
Pontuação 4
Adicionar um comentário
1 resposta
Solução escolhida
You need a keyboard. There are diagnostic lights to the left of the RAM slots, open it up and try to start it and let us know the status of the LEDs. Use this guide as a start to get into it: Substituição da fonte de alimentação do iMac Intel 21,5" EMC 2308
Esta resposta foi útil?
Pontuação 4
2 comentários:
I checked it and no light from the LEDs. I am not sure if I am looking at the right place.
What should I do now?
por
If your machine is completely dead (nothing) check the wall plug first, replace the electrical cable, replace the power supply.
por
Adicionar a sua resposta
Daniel será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 3
Ao todo: 12,020
