GE front load washer won't drain after rinse or spin
My washer goes thru the wash cycle but will not drain for the final spin
Esta é uma boa pergunta?
Cause 1
Drain Pump
Sometimes, small objects or articles of clothing can get caught in the drain pump. To determine if anything is blocking the drain pump, remove the drain pump and check the pump for obstructions. If the drain pump is clear of obstructions, but is still noisy during the drain cycle, replace the drain pump.
Cause 2
Clogged Pump or Hose
Sometimes, socks and other small articles of clothing can get into the drain system and clog the pump hose or the pump itself. Remove the hoses from the pump and check for any obstructions.
Cause 3
Lid Switch Assembly
The lid switch assembly prevents the washer from spinning when the lid is open. If the lid switch assembly fails, the washer will not drain. To determine if the lid switch assembly is defective, use a multimeter to test each of the lid switches for continuity. If a lid switch does not have continuity, replace it.
Esta resposta foi útil?
Últimas 24 horas: 0
Últimos 7 dias: 7
Últimos 30 dias: 28
Duração total: 3,572
3 comentários
Hi @rickster1 ,
What is the model number of the washer?
If it doesn't drain after the rinse and during the final spin, it sounds as though the drain pump is faulty or blocked.
por jayeff
Why would my not drain after the wash cycle but will drain after the rinse ? I would think if the pump is stopped up or bad it just wouldn’t drain at all . Am I wrong ?
por Julie Mackie
Hi @Julie Mackie,
What is the model number of the machine?
It may be the timer switch has a faulty contact when it comes to draining after the wash.
Can you manually step the timer control forward a notch to see if the machine starts to drain after the wash (agitate) cycle has finished?
por jayeff
