Ir para o conteúdo principal
Model A1174 with 2 GHz Core Duo or Model A1207 with 2.16 or 2.33 GHz Core 2 Duo
20 Perguntas Visualizar todos
? folder when rebooting, iMac knocked over
this exact same thing started happening to me after my dog knocked over my imac. it was running funny so I rebooted and got the folder with the "?" is it possible the hard drive was just knocked loose? when I boot from install CD the hard drive doesn't even show up as accessible to test or verify. Thanks!
Esta é uma boa pergunta?
Pontuação -1
Adicionar um comentário
1 resposta
Solução escolhida
jea, this folder means, the imac don't know from where to boot. this could be a bug all the way from the hard drive to the main board. this means, a connector unplugged itself or the hard drive fail.
if last happened, you need a new hard drive, but don't need to say ;)
good luck
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Cory Eman será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Ao todo: 830
