Ir para o conteúdo principal
The fourth version of Sony's famous Walkman cassette player, the WM-4 was introduced in 1983.
10 Perguntas Visualizar todos
The rotating cylinders in the walkman are not rotating. pls help!
So this is the closest thing to a walkman WM1 if you don’t know its ok.
the rotating thingies of my walkman don’t spin
, i already lost a tape due to it not spinning, it got tangled and then we had to cut it, i loved that tape, it had used to work but then i accidentally dropped it in my bedroom on the soft floor. it worked before so i don’t know what to do, help will be appreciated. (the cassette was guardians of the galaxy 1)
Thanks
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
The capstans are driven by rubber belts which perish after a number of years. Whilst it is possible to obtain spares in various sizes, fitting them is likely to be very tricky.
Esta resposta foi útil?
Pontuação 1
1 comentário:
THX, ill see if it works
por
Adicionar a sua resposta
Hasleno será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 9
Últimos 30 dias: 42
Duração total: 2,178
