Ir para o conteúdo principal
Model A1311 / Mid 2011 / 2.5 & 2.7 GHz Core i5 or 2.8 GHz Core i7 Processor
432 Perguntas Visualizar todos
Hard Drive Issues: Code 8. What does it mean?
Hello to all, I hope you are having a good day.
About a week ago my iMac would not boot up. So I took to the internet to figure out what the problem might be and came across some useful information.
I can boot up to Disk Utility and I see the hard drive and the space it has and everything but once I start running First Aid it tells me this:
Repairing file system.
  • Checking Journaled "***" volume.
  • Checking extents overflow file.
  • Checking catalog file.
  • Invalid key length
  • The Volume "****" could not be verified completely.
  • File system check exit code is 8.
  • Updating boot support partitions for the volume as required .
  • File system verify or repair failed.
Operation failed.
If i run it again, it bugs out and says there is no space on the hard drive. In the Info tab it says it can be Verified and Repaired but i have no idea how.
I have tried /sbin/fsck -fy in single user boot but it says that it cant do anything.
I restored it to the external hard drive I was going to use to back it up but it shows the same thing when i run First Aid.
So my questions are:
  • Is It Fixable?
  • Is there any way I can fix this problem without losing all the data stored on the HD?
  • If not how can I recover all the data before I fix it?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Solução escolhida
You’ll need to boot up under an external bootable drive to fix your drive. I would recommend you make a full backup using TimeMachine so you can properly fix your drive. Sadly it will need to be reformatted and a fresh OS install (MacOS & Windows) to fix this as the boot sectors are damaged. Often times I see this with BootCamp installations when a Windows virus attacks the drives boot sectors.
I would strongly recommend you get a good antivirus app that runs under MacOS & Windows as well.
Here’s how to create the needed boot drive: How to create a bootable macOS Sierra installer drive Go to your Apps Store app and open the Purchase tab to locate your OS to re-down load it.
Esta resposta foi útil?
Pontuação 2
press command and s after that press button to fix the error fsck and y and it will fix the driver error code.
Pontuação 0
1 comentário:
por
Adicionar a sua resposta
NamelessChat será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 10
Duração total: 8,114
