Ir para o conteúdo principal
A large smartphone by LG, released in fall 2014. The LG G3 (D855) boasts a Quad HD IPS display and a 13-megapixel camera.
battery only charges if removed and reinstalled
battery only charges if its removed and then reinstalled into the phone ( wall charging) ordered a replacement battery and it does the same thing . But replacement was supposed to be new but has a manufacturer date of Jan. 2015 bad battery or phone Thank You
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Have you tried other chargers? It sounds like you are having some type of grounding issue. The manufacture date is probably correct as the G3 is a very old phone and not produced anymore. I would maybe buy another battery from another supplier just to rule that out.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
lance buell será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Ao todo: 66
