Ir para o conteúdo principal
Model A1136 / 30, 60, or 80 GB hard drive / black or white plastic front
798 Perguntas Visualizar todos
Lagging iPod 5th Generation
Hey guys,
My iPod 5th Generation lags when I play certain songs. I’ve tried already a lot of possiblities: first deleting only this album, uploading it again, but the same. Then restoring the iPod through iTunes, then I upload again three albums and already at the 5th song starts to lag.
At this point I can feel while holding in my hand that the hard drive is lagging too. I can escape of this only with the two button reset. After that everything is fine again till I get to one song where it starts to lag again.
How could I solve this problem? Do I need to change the hard drive, or there is other possibilities?
Esta é uma boa pergunta?
Pontuação 0
2 comentários
which iPod 5 is this? sounds like the original...
por
iPod 5th G. 60gb Serial No : 8K632DWKWEF
por
Adicionar um comentário
1 resposta
Solução escolhida
I think you are correct that it is the HDD, the iPod is several years old and has likely played a fair few tunes in its time. You will need to find a new HDD and follow this guide
iPod 5th Generation (Video) Hard Drive Replacement
read the guide a few times, take your time and it should be fine.
Esta resposta foi útil?
Pontuação 4
1 comentário:
Mine went a few years ago ended up putting in a SSD unit Tarkan iFlash-Dual SD Card Adapter For iPod 5 Generation and Later best upgrade I could have done!
por
Adicionar a sua resposta
Tamas David será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 5
Últimos 7 dias: 12
Últimos 30 dias: 16
Duração total: 356
