Ir para o conteúdo principal
The Nikon D5200 is an F-mount DSLR camera with a 24.1 megapixel DX-format CMOS image sensor. The D5200 has a maximum resolution of 6000x4000 and is capable of 1080p video recording.
Why is the pop-up flash stuck up?
The pop up flash of the Nikon D 5200 is stuck up and would not open even on pressing various buttons or changing various settings. An external flash when mounted on the flash shoe works well though
Esta é uma boa pergunta?
Pontuação 2
Adicionar um comentário
3 respostas
See if either of these fits your issue:
Flash won’t click down
https://www.youtube.com/watch?v=e39dk_D9...
Flash won’t pop up
https://www.youtube.com/watch?v=_d7j9Gba...
Esta resposta foi útil?
Pontuação 0
我的也是,修还没必要,硬抠吧
Pontuação 0
Not totally sure what's causing that, but I’ve heard it can sometimes be a mechanical issue with the pop-up flash spring or latch. Since your external flash works fine, at least you’ve got a solid backup. Still, if you rely on the pop-up, it might be worth getting it checked out by a camera technician — just to be safe.
Pontuação 0
Adicionar a sua resposta
Raghavan V será eternamente grato(a).
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 4
Últimos 30 dias: 5
Ao todo: 2,569
