Ir para o conteúdo principal
Repair guide and technical information for the Dell Chromebook 11 series, including the standard clamshell and 2-in-1 convertible models. Covers disassembly, replacement parts, and common fixes for displays, keyboards, batteries, and other components.
plug does not stay in due to chp
The laptop is chipped where you put the cord in so it does not stay in and therefore does not charge well.  How do I go about getting that fixed?
Esta é uma boa pergunta?
Pontuação 1
1 comentário:
Can you post a picture of the damage? The severity and location will affect the efficacy of the repair.
por
Adicionar um comentário
1 resposta
You might try wrapping some tape around the plug in order to make it thicker.  If it is thicker, it may stay in the socket better than it is now doing, and if it therefore stays in the socket, it may be able to charge.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Elizabeth Moskat será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 5
Ao todo: 208
