Can I take case off only and still be safe?
I want to take off the rear of the Macintosh plus case and still be safe? i only want to take the back off and clean it. I dont want to touch any of the components.
Esta é uma boa pergunta?
Yes, taking the cover off and not putting your hands on the side mounted power supply you’ll be OK.
Use a paint brush to scrub the surfaces to loosen the dust and then use a can of can’ed air to blow it away. Don’t touch the yoke as you could alter its alignment and the CRT tube its self is fragile! So don’t bang it!
Esta resposta foi útil?
Últimas 24 horas: 2
Últimos 7 dias: 7
Últimos 30 dias: 10
Duração total: 428
