Ir para o conteúdo principal
The OP-1 is a portable music workstation incorporating a synthesizer, sampler, sequencer, multitrack recorder, drum machine, mixer, and controller. It was released in 2011.
49 Perguntas Visualizar todos
Why won't the screen turn on even though everything else works well?
New unit, purchased about four weeks ago.
About two weeks ago the screen stopped working. The rest of the unit seems to be working well, sounds come out of the unit when I press keys, and I can toggle through different functions, however I’m working blind.
I tried to do a reset (COM while turning on + pressing 7 after ) however this didn’t work.
I tried to connect to my computer to then upload firmware, but unfortunately when I connect the unit (after turning on with COM + pressing 1 after) it doesn’t show up as a drive in my MAC. I’m not sure if this is a cable issue, as I’m using the one provided by TE.
The unit is still under warranty, but given that TE just announced they will discontinue, returning it would mean I will not be getting one back. Any help would be deeply appreciated!
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
Hi.
I have the same problem, exactly how you are saying. I make to my store, and they him will give me another unit.
Best regards.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
melendez.g será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 4
Últimos 7 dias: 5
Últimos 30 dias: 9
Duração total: 433
