Ir para o conteúdo principal
iPhone 6 rear case replacement - Adhesive for rear case circuitry?
Hello,
This will be my first forum posting on iFixit.com. I tried thoroughly searching for my particular question in the forums but I couldn’t find the answer or it’s possible it hasn’t been asked. As I mentioned in the title, I’ll be working on a rear case replacement for the iphone 6. I’ve already resurrected the same phone from water damage by disassembling the phone, with the exception of removing the very thin flex ribbon cables that are glued to the rear casing and that are connected to the various system components, i,e., charging and 3.5 mm audio jack, power button and volume control circuitry and also the EMI shielding. I did a thoroughly cleaning using 99.9% isopropyl alcohol, dried it and managed to get it functioning again without issue. I’m aware from some iFixit guides that in order to do a rear case replacement, all the circuitry that is adhered to the inside of the rear case has to be taken off carefully with a flat tool such as a spudger.
My question is: Do I require any sort of adhesive for all the components after removal or is the adhesive adherent or sticky enough for me to simply remove the components, swap the rear casing and place the components back on the new rear casing? I understand that some websites that I’ve seen do sell, i.e., iphone 6 charging port and audio jack adhesive so will it be necessary for all or any components such as the charging port?
I appreciate your help, comments and/or suggestions in advance.
Thanks,
Mike
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
Solução escolhida
If the flat cables on the old housing are still functional you can remove them with the help of moderate heat and if you don’t keep them hanging around catching dust they are usually reusable on the new housing. They are surely of a better quality than what you find aftermarket. Whatever is not working and needs replaced usually comes with biadhesive already applied. The only really tricky part is the charging assembly as it’s glued to the housing with a special conductive adhesive for antenna grounding.. take your time to make sure that it doesn’t stick to the housing and apply some mild heat when you place it on the new part so that it sticks properly or you might have troubles with radio signals.
Esta resposta foi útil?
Pontuação 2
Adicionar a sua resposta
mweinsteinca será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 1
Duração total: 45
