Ir para o conteúdo principal
7.9 inch display / Model A1432 / Available in black or white / Announced October 23rd, 2012 / 16, 32, or 64 GB capacity
How to fix a bent back of ipad min?
Accidentally bent the ipad min a little bit. It now gaps a little bit on both side. How do I get it to refit the ipad mini?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
At minimum, remove the digitizer and LCD, then use a tool such as the gTools PanelFormer Pro to coax the frame back into straightness, then put the LCD and digitizer back in.
https://www.fixez.com/categories/repair-...
Esta resposta foi útil?
Pontuação 0
1 comentário:
That is a delicate tool to use to fix aluminum housing, I would just slowly bend the frame and straighten it out with bare hands (with digitizer/LCD and logic board removed of course).
por
Adicionar a sua resposta
Alice Lee será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 2
Ao todo: 594
