Replaced the battery with iFixit battery, now Trackpad not working
After battery replacement with iFixit 2012 MacBook Air battery, trackpad is not working now.
Esta é uma boa pergunta?
Hi guys, just to close this out. When I replaced the battery, I mistakenly removed the trackpad setting screw. (in the front middle) when I realized my mistake, then I didn’t know how to reset it. By trial and error, I reset it so that the head was exactly flush with the surface. Do Not tighten this screw, it is a setting screw. Flush with surface got the trackpad working perfectly.
Thanks to you all for your support.
Esta resposta foi útil?
There are two possibilities here:
You either have damaged the uppercase cable. Or the trackpad its self has failed. Here’s the IFIXIT guide you’ll need to follow to get to both MacBook Air 13" Mid 2012 Trackpad Replacement. Jump to step 6 to see the upper case cable MacBook Air 13" (Mid 2011-Mid 2012) Trackpad Cable and here’s the trackpad MacBook Air 13" (Mid 2012) Trackpad
Produto
$14.99
Produto
$94.99
Sorry, I meant the trackpad.
Try reseating the trackpad cable on both ends it may have gotten loose after doing the battery replacement.
Was the old battery swollen?
Hi Mayer, the old battery looks ok.
I bought a mouse and can at least use my mba again. Trackpad still kaput.
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 11
Duração total: 165
