Ir para o conteúdo principal
iPhone de quarta geração lançado em 2010. O reparo é simples, mas o vidro frontal e o LCD devem ser substituídos juntos, como uma unidade. GSM / 8, 16 ou 32 GB de capacidade / Modelo A1332 / Preto e Branco.
2376 Perguntas Visualizar todos
iTunes error code 2015 during iPhone 4 restore
Hi,
I have an iPhone 4 which bootloops and have been trying to restore or update it via itunes. I have disassembled it to replace the screen so warranty is out of the question(it’s “obsolete” anyway). I plug the phone into my pc whilst holding down the home button and the itunes/lightning logo shows up on the iphone and itunes detects it. I then get the option to upgrade or restore and I click restore. The bar at the top says ‘Extracting Software’ however after that, I hear the device being ejected then reconnected, the phone reboots and I get ‘Unknown error 2015’. Does anyone have a possible solution?
Thanks
Esta é uma boa pergunta?
Pontuação 2
Adicionar um comentário
2 respostas
Solução escolhida
Thanks but I realised all I did was accidentally disconnect the battery so it rebooted whenever the usb power was disconnected.
Esta resposta foi útil?
Pontuação 1
Pergunta mais útil
Boot loop and error 2015 is a hardware failure issue. iPhones do a health checkup during the booting process, and if there is a damaged part somewhere, you will get a boot loop and restore errors. This error usually revolves around front camera/speaker flex cable or the rear camera. But that is just the majority of failures for this issue. Have you checked for any damaged parts during the screen replacement?
Pontuação 2
1 comentário:
Thanks toreskey. I was starting to assume somethings is damaged inside as I also looked at the log files and system information and assumed there is a lot of info missing from the device.
Are you or anyone aware of what step I should take next in discovering what part might need replacing? The phone looks absolutely perfect. History: It was found on a fishing boat - so I am assuming water damage. In one of the log files it look like apple checked the battery and it said fully charged. I can send log files if helpful. Thanks
por
Adicionar a sua resposta
jamiebrowm será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 4
Últimos 7 dias: 10
Últimos 30 dias: 65
Duração total: 17,410
