Chrome is totally frozen, and Shift + Esc does not work. Unfreeze?
I cannot unfreeze Chrome on HP Chromebook. No keys do anything, and no cursor or trackpad function is working. How do I reboot it?
Esta é uma boa pergunta?
Try this first…
https://www.schooledintech.com/how-to-fo...
You have not indicated if the power button works or not. Try holding that down to power off. If that doesn’t work you may have to fully discharge the battery to power off… You can then recharge for a while and then power back up. If this recurs you may have bad hardware somewhere like failing RAM chip or something.
Esta resposta foi útil?
Try ESC - RELOAD - POWER
press CTRL - D
press ENTER
press ESC
Your data might be erased, but might not
Try and let me know
Actually, I sort of fixed it. I just let the laptop run in its loop unplugged from the AC outlet and let the battery run down to zero. I was able to reboot the computer when I repowered it.
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 13
Duração total: 291
